MasterFan MF120 Halo ARGB 120mm Case Fan image number 0
MasterFan MF120 Halo ARGB 120mm Case Fan image number 1
MasterFan MF120 Halo ARGB 120mm Case Fan image number 2
Halo of Light
MasterFan MF120 Halo, a new series to the MasterFan family, provides a specific air cooling solution ideal for CPU coolers and chassis in-take fans...
Buy Now
  • RGB Rated Voltage 5 VDC
  • LED Lighting ARGB
  • RGB Connector 3-Pin
  • Number of LEDs 24pcs
  • Fan Air Pressure 1.6 mmH2O ± 10%
  • Cooler Type Case Fan
  • Fan MTTF 160,000 Hours
  • Fan Bearing Type LDB
  • Fan Noise Level 6 - 30 dBA
  • Fan Safety Current 0.37A
  • Fan Size 120
  • RGB Rated Current 0.55A (0.8A Max)
  • Note Products manufactured after 1st June 2021 are Addressable Gen 2 RGB LEDs
  • Fan Profiles Addressable Gen 2 RGB
  • Series MasterFan
  • Fan Power Consumption 3.0W
  • Fan Rated Current 0.25A
  • Fan Weight 180g / 0.4lbs
  • Fan Speed 650-1800 RPM ± 10%
  • Fan Airflow 47.2 CFM ± 10%
  • Product Number MFL-B2DN-18NPA-R1
