Mini-Charge Tool image number 0
Compact. Reliable. Ready to Recharge.
Mini-Charge Tool
Overview The Cooler Master CDU Mini-Charge Tool is an efficient coolant-filling solution for the Cooler Master 25 kW and 100 kW CDUs and rack manifolds to the data center IT hardware cold plate. Its pump and compressor deliver a 25-micron-filtered coolant at a maximum pressure of 70 psi from a coolant tank.
Features and Benefits
Features:
  • Handle for portability
  • Operation status indicator light
  • Quick disconnect fittings
  • C14 power connector
Benefits:
  • Easily transportable device
  • Simple control with only On and Off
  • UL-certified
  • Shut off connectors to ensure no liquid spills!
  • Wide coolant compatibility
Power Precision in a Compact Form
Engineered for high-efficiency charge management, the Mini-Charge Tool delivers precise control and streamlined performance in a space-saving design.
Whether you're optimizing power delivery for sensitive components or managing dynamic load conditions, this tool is built to handle complex electrical environments with accuracy. Unlike bulky legacy systems or costly industrial setups, the Mini-Charge Tool offers a smart, scalable solution—bridging the gap between lab-grade precision and real-world practicality.
Mini Charge Tool
