300 kW AALC CDU image number 0
300 kW AALC CDU
Overview The Cooler Master 300 kW AALC (Air-Assisted Liquid Cooling) CDU offers high-heat-load management for IT hardware, dissipating up to 300 kW of thermal energy. This system delivers exceptional energy efficiency through its innovative design, ensures operational reliability with robust components, and offers flexible deployment options suitable for various modern IT environments. The system architecture features two V-patterned radiators and eight hot-swappable fans per rack, enabling efficient heat exchange with an approach temperature difference from 3 to 5°C. This liquid-to-air CDU is designed for deployment in existing data centers without built-in liquid cooling infrastructure. It is fully compatible with current GB200 and GB300 GPU server racks, as well as future VR200 systems.
Features & Benefits
Features
  • 380 to 480 V ac compatibility for direct drive EC fans and pumps.
  • Independent pump and HEX racks for lower noise and better energy efficiency
  • Field replaceable units (FRUs): pump, fan, filters, CRPS, BBU, expansion tank, air vent; all with quick disconnects (QDs) for easy maintenance.
  • Redundant components: pumps (2+1), fans (2 x 7+1), and filters (1+1) for reliability.
  • UPS support for up to 90 seconds during a power outage.
  • EMI-compliant bonding for stable EMC performance
  • Factory Hi-Pot & grounding verification for reliable installation
  • Acoustic signature below 90 dBA.
  • Cross-rack manifold enables direct rack IT integration.
  • Self-diagnostics with real-time monitoring.
  • User-friendly interface for live status, alarms, and controls.
Benefits
  • Optimized efficiency via direct drive technology.
  • Quieter operations and improved productivity.
  • Faster maintenance with quick disconnects (QDs).
  • Reliable performance through redundant subsystems and UPS-supported uptime.
  • Stable EMC/safety via bonded enclosure and verified grounding.
  • Smart monitoring with sensor readings and self-diagnostics.
  • Setup flexibility with a user-friendly interface and remote management.
