Wall Manifold image number 0
Wall Manifold
Overview The Wall Manifold is designed for data center server rooms and works in tandem with the CDU. It helps redirect CDU pipeline flow, allowing more flexible and efficient connections to server racks. This setup simplifies integration with the cabinet's liquid cooling system, improving layout adaptability and thermal management in high-density environments.
Feature & Benefits:
Can be installed freely and flexibly to suit different locations and site layouts.
Simple and fast installation process.
High reliability for long-term use.
