XG850 Platinum image number 0
XG850 Platinum image number 1
XG850 Platinum image number 2
XG850 Platinum image number 3
XG850 Platinum image number 4
XG850 Platinum image number 5
XG850 Platinum image number 6
XG850 Platinum image number 7
XG850 Platinum image number 8
XG850 Platinum image number 9
XG850 Platinum
XG850 Platinum
XG850 Platinum
XG850 Platinum
XG850 Platinum
XG850 Platinum
XG850 Platinum
XG850 Platinum
XG850 Platinum
XG850 Platinum
Full Modular 80 PLUS Platinum Power Supply with Smart Thermal Control Mode
XG850 Platinum
• Intel ATX 12V Ver. 3.1
• 80 PLUS Platinum & Cybenetics Platinum certifications
• Cybenetics A++ noise level certification
• Quiet 135mm Fan
• Smart Thermal Control Mode with Hybrid Switch
• Full-Modular Cabling
• 10-Year Warranty
XG850 PLATINUM
FULL MODULAR 80 PLUS PLATINUM POWER SUPPLY WITH SMART THERMAL CONTROL MODE
certifications
• Quiet 135mm Fan
• 10-Year Warranty
Crafted for excellence
This professional grade power supply unit is built with full-bridge LLC resonant converter and DC-DC technology, made for the all users providing stability, reliability and so much more.
A - High permeability PFC inductors, improve power factor
B - All-Japan capacitor, make XG have longer life
C - LLC Topology makes XG more Efficient
D - Uniquely designed transformer with lower heat
E - High-performance synchronous rectification
F - DC to DC Converter
Silence is platinum
Silence is platinum
XG850 Platinum has been certified by Cybenetics for both Platinum efficiency and an A++ noise level. It delivers over 92% efficiency at typical loads and maintains an average noise level below 15dB(A) through its smart thermal control system.
Built to last
Built to last
With a 10 years warranty, you’ll be using this longer than most up to date home consoles and most of the other components in your system.
  • Model MPG-8501-AFBAP-**
  • ATX Version ATX 12V Ver. 2.53
  • Input Current 12-6A
  • Fan Size 135mm
  • Fan Speed 1800 RPM
  • Noise Level @ 100% ≤ 25 dBA
  • Hold Up Time ≥ 20ms
  • Protections OPP
  • Protections OVP
  • Protections OCP
  • Protections UVP
  • Protections SCP
  • Protections OTP
  • Protections Surge and Inrush Protection
  • Regulatory TUV
  • Regulatory cTUVus
  • Regulatory CE
  • Regulatory BSMI
  • Regulatory FCC
  • Regulatory CCC
  • Regulatory EAC
  • Regulatory UKCA
  • EPS 4+4 Pin Connectors 1
  • EPS 8 Pin Connector 1
  • SATA Connectors 12
  • PCI-e 6+2 Pin Connectors 6
  • Series XG Series
  • Category Above 750W
  • 80 Plus Efficiency Platinum
