XG750 Plus Platinum image number 0
XG750 Plus Platinum image number 1
XG750 Plus Platinum image number 2
XG750 Plus Platinum image number 3
XG750 Plus Platinum image number 4
XG750 Plus Platinum image number 5
XG750 Plus Platinum image number 6
XG750 Plus Platinum image number 7
XG750 Plus Platinum image number 8
XG750 Plus Platinum
XG750 Plus Platinum
XG750 Plus Platinum
XG750 Plus Platinum
XG750 Plus Platinum
XG750 Plus Platinum
XG750 Plus Platinum
XG750 Plus Platinum
XG750 Plus Platinum
Full Modular 80 PLUS Platinum ARGB Power Supply with Digital Options
XG750 Plus Platinum
• Intel ATX 12V Version 2.53
• 80 PLUS Platinum Certified
• Quiet ARGB 135mm silent Fan
• Built-in Information Display Panel
• Full-Modular Cabling with 100% Japanese In-Line Capacitors
• 10-Year Warranty
XG750 PLUS PLATINUM
FULL MODULAR 80 PLUS PLATINUM ARGB POWER SUPPLY WITH DIGITAL OPTIONS
• 10-Year Warranty
Powered By Cooler Master
The XG Plus Platinum marks the culmination of many years of effort and the beginning of a new era for Cooler Master power supply units. This product line debuts the first generation of power supply platform created by Cooler Master in-house. This platform allows Cooler Master to offer an entirely new class of high efficiency products. The use of 100% Japanese capacitors allows this power supply unit to deliver top-shelf performance with reduced ripple noise.
Silence is Platinum
Some power supply units offer great cooling performance. And some offer quiet operation. The XG Plus Platinum offers both. The in-house designed was created so that we could deliver a high quality PSU that could power gaming builds at top of the line performance levels while remaining relatively cool.
  • EPS 4+4 Pin Connectors 1
  • EPS 8 Pin Connector 1
  • USB Protocol 10P 1
  • Category 500 to 750W
  • 80 Plus Efficiency Platinum
  • SATA Connectors 12
  • Fan Size 135mm
  • PCI-e 6+2 Pin Connectors 4
  • Protections OVP
  • Protections OPP
  • Protections SCP
  • Protections UVP
  • ATX Version Intel ATX 12V Ver. 2.53
  • Protections OTP
  • Protections OCP
  • Fan Speed 1800 RPM
  • Protections Surge and Inrush Protection
  • Regulatory CCC
  • Input Current 10-5A
  • Regulatory CE
  • Series XG Series
  • Regulatory EAC
  • Regulatory cTUVus
  • Regulatory FCC
  • Regulatory BSMI
  • Hold Up Time ≥ 16ms
  • Regulatory TUV
  • Noise Level @ 100% ≤ 25 dBA
  • Regulatory UKCA
  • Model MPG-7501-AFBAP-X**
