XG750 Platinum image number 0
XG750 Platinum image number 1
XG750 Platinum image number 2
XG750 Platinum image number 3
XG750 Platinum image number 4
XG750 Platinum image number 5
XG750 Platinum image number 6
XG750 Platinum image number 7
XG750 Platinum image number 8
XG750 Platinum image number 9
XG750 Platinum
XG750 Platinum
XG750 Platinum
XG750 Platinum
XG750 Platinum
XG750 Platinum
XG750 Platinum
XG750 Platinum
XG750 Platinum
XG750 Platinum
Full Modular 80 PLUS Platinum Power Supply with Smart Thermal Control Mode
XG750 Platinum
• Intel ATX 12V Ver. 3.1
• 80 PLUS Platinum & Cybenetics Platinum certifications
• Cybenetics A++ noise level certification
• Quiet 135mm Fan
• Smart Thermal Control Mode with Hybrid Switch
• Full-Modular Cabling
• 10-Year Warranty
XG750 Platinum
FULL MODULAR 80 PLUS PLATINUM POWER SUPPLY WITH SMART THERMAL CONTROL MODE
•Cybenetics A++ noise level certification
• Quiet 135mm Fan
• 10-Year Warranty
Crafted For Excellence
This professional grade power supply unit is built with full-bridge LLC resonant converter and DC-DC technology, made for the all users providing stability, reliability and so much more.
A - High permeability PFC inductors, improve power factor
B - All-Japan capacitor, make XG have longer life
C - LLC Topology makes XG more Efficient
D - Uniquely designed transformer with lower heat
E - High-performance synchronous rectification
F - DC to DC Converter
Silence is Platinum
Silence is Platinum
XG750 Platinum has been certified by Cybenetics for both Platinum efficiency and an A++ noise level. It delivers over 92% efficiency at typical loads and maintains an average noise level below 15dB(A) through its smart thermal control system.
Built to Last
Built to Last
With a 10 years warranty, you’ll be using this longer than most up to date home consoles and most of the other components in your system.
  • EPS 4+4 Pin Connectors 1
  • EPS 8 Pin Connector 1
  • Category 500 to 750W
  • 80 Plus Efficiency Platinum
  • SATA Connectors 12
  • Fan Size 135mm
  • PCI-e 6+2 Pin Connectors 4
  • Protections OVP
  • Protections OPP
  • Protections SCP
  • Protections UVP
  • Protections OTP
  • Protections OCP
  • Protections Surge and Inrush Protection
  • Fan Speed 1800 RPM
  • Regulatory CCC
  • Input Current 10-5A
  • Regulatory CE
  • Series XG Series
  • Regulatory EAC
  • Regulatory cTUVus
  • Regulatory FCC
  • Regulatory BSMI
  • Hold Up Time ≥ 20ms
  • Regulatory TUV
  • Noise Level @ 100% ≤ 25 dBA
  • Regulatory UKCA
  • Model MPG-7501-AFBAP-**
