X Silent MAX Platinum 1300 image number 0
X Silent MAX Platinum 1300 image number 1
X Silent MAX Platinum 1300 image number 2
X Silent MAX Platinum 1300 image number 3
X Silent MAX Platinum 1300 image number 4
X Silent MAX Platinum 1300 image number 5
X Silent MAX Platinum 1300 image number 6
X Silent MAX Platinum 1300 image number 7
PRECISE SILENT POWER
• Equipped with an Ultra-Quiet Mobius Fan
• Active Bridge Rectifier replaces diodes
• Minimize Electromagnetic Noise
• Industrial-Grade Infineon IC
• Digital Power Management System
• 15-year warranty
region
Mobius Fan
Supreme Silence
Our design integrates an ultra-silent Mobius fan with an exclusive aluminum
heat sink for improved cooling efficiency. Combined with unique inductors that
minimize electromagnetic noise, it ensures an exceptionally quiet experience.
Fully Modular Cabling
Modular cabling minimizes clutter, while the additional ports provide extra functionality.
Exclusive Design
Superior Cooling Performance
Our exclusive aluminum Thermal Mold efficiently disperses heat, while the ultra-silent Mobius fan strengthens the airflow to lower the temperature across the unit. This dual approach guarantees effective thermal management, maintaining optimal performance and extending the lifespan of the PSU.
Active Bridge Rectifier Boosts Efficiency 2%
The Active Bridge Rectifier, equipped with the Infineon CoolMOS, marks a significant advancement in power efficiency. This innovative combination not only conserves electricity, but also significantly reduces power loss, outperforming traditional bridge diodes. It's an ideal solution for users seeking eco-friendly, high-efficiency power supply units.
ATX 3.1 Support & a Durable 90° 12V-2X6 Cable
Includes ATX 3.1 support and a 90° 12V-2x6 connector featuring more reliability, higher electrical durability, improved safety, and capable of bringing up to 600W to your GPU.
  • Model MPS-D001-AFAP
  • Input Current 15-7.1A
  • Fan Bearing LDB
  • Fan Speed 2050 RPM
  • Hold Up Time ≥ 16ms
  • Regulatory cUL, TUV, CE, FCC, BSMI, CCC, EAC, RCM, UKCA/BIS, KC (based on region's request.)
  • EPS 4+4 Pin Connectors 1
  • EPS 8 Pin Connector 1
  • SATA Connectors 16
  • PCI-e 6+2 Pin Connectors 4
  • 12V-2x6 Connectors 1
  • USB 10P Connector 1
  • Series X Series
  • 80 Plus Efficiency Platinum
  • Category Above 750W
  • Watts 1300W
  • ATX Version ATX 3.1
  • Input Voltage Range Full Range
