X Dream P115 CPU Air Cooler image number 0
X Dream P115 CPU Air Cooler image number 1
Cooler Master X Dream P115 is a low profile aluminum extrusion fin CPU cooler with only 48.8mm/1.93 in height for a system with limited space.
  • Cooler Type Air Cooler
  • Rated Voltage 12 VDC
  • Connector 4-Pin
  • Bearing Type LDB Bearing
  • Fan Life Expectancy 70,000 Hours
  • Series X Dream
  • CPU Socket LGA1200
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • Heat Sink Dimensions (L x W x H) Ø95 x 22 mm / 3.74 x 0.87 inch
  • Heat Sink Material Aluminum
  • Fan Noise Level 19 - 36 dBA
  • Fan Dimensions (L x W x H) Ø95 x 25 mm / 3.74 x 0.98 inch
  • Fan Air Pressure 6.7 mmH2O ± 10%
  • Fan Speed 900 RPM ± 10% (Duty Cycle 30 %)
  • Fan Speed 4000 RPM ± 10% (Duty Cycle 100%)
  • Fan Airflow 52 CFM ± 10%
  • Product Number RR-X115-40PK-R1
  • CPU-Z - Cooler Master 32 & 64-bit versions Download
