X Dream I117 CPU Air Cooler image number 0
X Dream I117 CPU Air Cooler image number 1
X Dream I117 CPU Air Cooler image number 2
X Dream I117 CPU Air Cooler image number 3
Cooler Master X Dream I117 is a low profile aluminum extrusion fin CPU cooler designed for a system with limited space.
  • Fan Life Expectancy 40,000 Hours
  • Cooler Type Air Cooler
  • Connector 3-Pin
  • Rated Voltage 12 VDC
  • CPU Support Core™ i7
  • Fan Bearing Type LDB
  • CPU Support Core™ i5
  • CPU Support Core™ i3
  • Series X Dream
  • CPU Support Pentium
  • CPU Socket LGA1200
  • Fan Dimensions (L x W x H) 95 x 95 x 20 mm
  • CPU Support Celeron
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • CPU Socket LGA775
  • Fan Power Consumption 2.16W
  • Fan Rated Current 0.18A
  • Heat Sink Material Aluminum
  • Fan Speed 1800 RPM ± 10%
  • Fan Noise Level 19 dBA (Min)
  • Weight 370g
  • Fan Air Pressure 1.55 mmH2O ± 10%
  • Dimensions (L x W x H) 112.2 x 112.2 x 60.4 mm
  • Fan Airflow 36.5 CFM ±10%
  • Product Number RR-X117-18FP-R1
