X Dream 4 CPU Air Cooler image number 0
X Dream 4 CPU Air Cooler image number 1
Cooler Master X Dream 4 CPU cooler is designed for Intel new dual core 65W Conroe family processors.
  • Fan Life Expectancy 40,000 Hours
  • Connector 3-Pin
  • Rated Voltage 12 VDC
  • Start Voltage 7 V
  • Operating Voltage 10.8-13.2 V
  • Legacy Cooling
  • Bearing Type Long Life Sleeve Bearing
  • Fan Dimensions (L x W x H) 92 x 92 x 25 mm / 3.6 x 3.6 x 1 inch
  • CPU Socket LGA775
  • Fan Power Consumption 2.16W
  • Fan Rated Current 0.18A
  • Heat Sink Dimensions (L x W x H) Ø90 x 32 mm
  • Heat Sink Material Aluminum
  • Fan Noise Level 17 dBA
  • Weight 260g
  • Fan Air Pressure 2.43 mmH2O
  • Fan Speed 2200 RPM ± 10%
  • Dimensions (L x W x H) 92 x 92 x 57 mm
  • Fan Airflow 33.75 CFM
  • Product Number RR-LEE-L911-GP
