Vortex Plus CPU Air Cooler image number 0
Vortex Plus CPU Air Cooler image number 1
Vortex Plus CPU Air Cooler image number 2
Vortex Plus CPU Air Cooler image number 3
Cooler Master Vortex Plus CPU cooler is a low profile CPU cooler with just 84mm height able to fit in HTPC chassis and LAN box chassis.
  • Cooler Type Air Cooler
  • Fan Life Expectancy 40,000 Hours
  • CPU Support Core™ i7 Extreme
  • Fan Bearing Type Long Life Sleeve Bearing
  • Connector 4-Pin
  • Note *The supplied accessories may differ by country or area. Please check with your local distributor for further details.
  • Heatpipes 4
  • CPU Support Core™ i5
  • CPU Support Core™ i3
  • CPU Support Core™2 Extreme
  • CPU Support Core™2 Quad
  • Fan Dimensions (L x W x H) 92 x 92 x 25 mm / 3.6 x 3.6 x 1 inch
  • CPU Socket LGA1366
  • CPU Support Core™2 Duo
  • CPU Support Pentium
  • CPU Socket LGA1200
  • Series Vortex
  • CPU Support Celeron
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • CPU Support AMD FX-Series
  • Fan Air Pressure 0.35 - 4.27 mmH2O ± 10%
  • Heat Sink Material 4 Heat Pipes
  • CPU Support AMD A-Series
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • CPU Support AMD Phenom™ II X4
  • CPU Support AMD Phenom™ II X3
  • CPU Socket LGA775
  • CPU Support AMD Phenom™ II X2
  • CPU Support AMD Phenom™ X4
  • CPU Support AMD Phenom™ X3
  • CPU Socket AM4
  • CPU Socket AM3+
  • CPU Support AMD Athlon™ II X4
  • CPU Support AMD Athlon™ II X3
  • CPU Socket AM3
  • CPU Support AMD Athlon™ II X2
  • CPU Support AMD Athlon™ X2
  • CPU Socket AM2
  • CPU Socket FM2+
  • CPU Support AMD Sempron™
  • CPU Socket FM2
  • CPU Socket FM1
  • CPU Support AMD Ryzen
  • Fan Noise Level 17 - 35 dBA
  • Weight 445g / 1lbs
  • Dimensions (L x W x H) 116 x 100 x 84 mm / 4.6 x 3.9 x 3.3 inch
  • Fan Airflow 15.7 - 54.8 CFM
  • Fan Speed 800-2800 RPM (PWM)
  • Product Number RR-VTPS-28PK-R1
