Compatibility
Compatible with all Standard ATX Chassis
The newly revised Vertical Graphics Card Holder Kit fits all standard ATX chassis, now providing even more options for adjusting graphics card position.
Make of It What You Will
Supporting cases ranging in size from m-ATX to ATX, and featuring a removable adjustable GPU bracket, this remastered design allows unprecedented compatibility with various builds and setups. A PCIe 4.0 riser cable is included to assist the installation process and ensure high efficiency at uncompromised speeds.
Allows for efficient data transmission and connectivity
between the latest hardware components
Designed for both ATX and mATX cases, this accessory is compatible with the latest GPUs available on the market
Bring the best out of your components by showing off your GPU
Compatibility
Compatibility
Compatibility with m-ATX cases is guaranteed thanks to the brand new design that simply requires 4 PCi slots for installation.
GPU connection to external monitors is facilitated due to the modular design, now 100% adjustable according to preference and needs.
The fully ventilated design is specially designed to allow unrestricted airflow for "flow-through" GPU coolers
