V850 Platinum image number 0
V850 Platinum image number 1
V850 Platinum image number 2
V850 Platinum image number 3
V850 Platinum image number 4
V850 Platinum image number 5
V850 Platinum image number 6
V850 Platinum image number 7
V850 Platinum image number 8
V850 Platinum image number 9
V850 Platinum image number 10
V850 Platinum
V850 Platinum
V850 Platinum
V850 Platinum
V850 Platinum
V850 Platinum
V850 Platinum
V850 Platinum
V850 Platinum
V850 Platinum
V850 Platinum
FULL-MODULAR 80 PLUS PLATINUM POWER SUPPLY
V850 Platinum
80 Plus Platinum Certified
Full-bridge LLC Resonant Converter and DC-DC Technology
Thermal Regulation Mode (TRM)
Single/multi-rail Switch
Improved PCI-E Cable Conductivity
10 Year Warranty
  • ATX Version ATX 12V
  • Category Above 750W
  • 80 Plus Efficiency Platinum
  • SATA Connectors 12
  • PCI-e 6+2 Pin Connectors 6
  • Fan Size 135mm
  • Input Voltage 100-240Vac
  • Fan Bearing TBB
  • Protections OVP
  • Protections OPP
  • Protections SCP
  • Series V Platinum Series
  • Protections UVP
  • Efficiency 92% Typical Load
  • Protections OTP
  • Protections OCP
  • Regulatory CCC
  • Regulatory CE
  • Input Current 12-6A
  • Regulatory RCM
  • Dimensions (L x W x H) 201.2 x 150 x 86 mm
  • Regulatory EAC
  • Regulatory cTUVus
  • Regulatory FCC
  • Regulatory BSMI
  • Regulatory KC
  • Regulatory TUV
  • Model MPZ-8501-AFBAPV
