V SFX Platinum 1300 230V ATX 3.1 White Edition image number 0
V SFX Platinum 1300 230V ATX 3.1 White Edition image number 1
V SFX Platinum 1300 230V ATX 3.1 White Edition image number 2
V SFX Platinum 1300 230V ATX 3.1 White Edition image number 3
V SFX Platinum 1300 230V ATX 3.1 White Edition image number 4
Industrial Leading SFX Power Supply
• High Power Density
• Fully support ATX 3.1
• 100% Japanese Capacitors
• Full-bridge LLC and DC-DC technology
• Fully Modular Cables
• 10-year Warranty
High Power Density
Adopting with the components miniaturization technology by the improvement of materials engineering, manufacturing process and leading thermal technology, the V SFX Platinum has achieved one of the highest power density, 30% more than V SFX Gold 850W power supply, in the small form factor.
Miniaturized But Solid
Crafted with flat copper wire on Choke of DC-DC, flat transformer piling and aluminum plate dissipation structure on full-bridge LLC, it can effectively achieve components miniaturization. Adopting with advanced manufacturing process, it simultaneously keeps miniaturized but solid.
Full & Flexible Compatibility
Designed to fully support ATX 3.1 and provide backward compatibility, supporting both RTX 40 and 30 series graphics cards, and alongside with included bracket to support both ITX and ATX cases, the V SFX Platinum offers a PSU with the most complete compatibility.
Enhanced Dissipation
With the integration of transformer and rectifier, full-bridge LLC heat dissipation structure, and the EMI-inhibited amorphous metal materials, the V SFX Platinum provideds advanced performance and heat dissipation.
  • Model MPZ-D001-SFBP-EG**
  • ATX Version ATX 3.1 & SFX 12V Ver. 3.42
  • Input Voltage 200-240V
  • Input Current 7.7A (Max.)
  • Fan Size 92mm
  • Fan Bearing FDB
  • Fan Speed 1900 RPM
  • Efficiency ≥ 94% @ Typical Load
  • 80 PLUS Rating 80 PLUS Platinum EU 230V
  • Hold Up Time ≥16ms at 60% Load
  • Protections OVP / OPP / SCP / OCP / UVP / OTP / Surge and Inrush Protection
  • EPS 4+4 Pin Connectors 1
  • EPS 8 Pin Connector 1
  • SATA Connectors 8
  • PCI-e 6+2 Pin Connectors 3
  • 12V-2x6 Connectors 1
  • Form Factor SFX
  • Watts 1300W
  • Series V SFX Series
  • 80 Plus Efficiency Platinum
