V SFX Gold 750 ATX 3.0 White Edition image number 0
V SFX Gold 750 ATX 3.0 White Edition image number 1
V SFX Gold 750 ATX 3.0 White Edition image number 2
V SFX Gold 750 ATX 3.0 White Edition image number 3
V SFX Gold 750 ATX 3.0 White Edition image number 4
V SFX Gold 750 ATX 3.0 White Edition image number 5
V SFX Gold 750 ATX 3.0 White Edition image number 6
V SFX Gold 750 ATX 3.0 White Edition image number 7
V SFX Gold 750 ATX 3.0 White Edition image number 8
Small But Mighty
• Flexible compatibility
• 80 PLUS Gold certified
• Fully modular cabling
• High-quality Japanese capacitors
• 10-year Warranty
ATX 3.0 Support & a Durable 90-degree 12VHPWR Cable
Flexible Compatibility
With the included SFX-to-ATX bracket, the V SFX Gold ATX 3.0 can be used to power systems ranging from as small as a mini-ITX all the way up to E-ATX motherboards.
100% Japanese Capacitors
Large, high-quality Japanese capacitors feature inmproved efficiency and reduced ripple noise.
80 PLUS Gold Certified
Fully modular Cabling
  • Model MPY-7501-SFHAGV-3W*
  • Input Current 10-5A
  • Fan Size 92mm
  • Fan Bearing FDB
  • 80 PLUS Rating 80 PLUS Gold
  • Hold Up Time 16ms
  • Regulatory TUV, cTUVus, CE, BSMI, FCC, CCC, EAC, RCM, CB, UKCA
  • EPS 4+4 Pin Connectors 1
  • EPS 8 Pin Connector 1
  • SATA Connectors 8
  • PCI-e 6+2 Pin Connectors 4
  • 12VHPWR Connector 1
  • 80 Plus Efficiency Gold
  • Series V SFX Series
  • Category Above 750W
  • Form Factor SFX
  • Watts 750W
  • ATX Version ATX 3.0
