V Platinum 1300 V2 image number 0
V Platinum 1300 V2 image number 1
V Platinum 1300 V2 image number 2
V Platinum 1300 V2 image number 3
V Platinum 1300 V2 image number 4
V Platinum 1300 V2 image number 5
V Platinum 1300 V2 image number 6
V Platinum 1300 V2 image number 7
V Platinum 1300 V2 image number 8
V Platinum 1300 V2 image number 9
V Platinum 1300 V2 image number 10
V Platinum 1300 V2 image number 11
V Platinum 1300 V2
V Platinum 1300 V2
V Platinum 1300 V2
V Platinum 1300 V2
V Platinum 1300 V2
V Platinum 1300 V2
V Platinum 1300 V2
V Platinum 1300 V2
V Platinum 1300 V2
V Platinum 1300 V2
V Platinum 1300 V2
V Platinum 1300 V2
QUIETLY SUPREME
V Platinum 1300 V2
Ultra-quiet Mobius fan improves airflow
Advanced heat dissipation
ATX 3.1 support & a durable 90° 12V-2x6 cable
Interleaved PFC design decreases power loss
80 Plus Platinum certification
12-year warranty
QUIETLY SUPREME
V Platinum V2 delivers silent operation, featuring an ultra-quiet Mobius fan, a protective conformal coating heatsink, smart thermal control, zero-RPM fan mode, fully modular cabling, and 80 Plus Platinum efficiency, backed by a 12-year warranty.
QUIETLY SUPREME
QUIETLY SUPREME
MOBIUS FAN ENHANCES THERMAL PERFORMANCE AND A LONGER LIFESPAN
An ultra-quiet Mobius fan featuring high-performance oil reflow, an innovative ring blade design, and accelerated pressure air vents provides improved noise levels and advanced thermal performance.
OIL FLOWS BACK TO THE SEALED BEARING, ENSURING CONSTANT LUBRICATION.
A loop dynamic bearing with a thick oil coating ensures stable performance, prolongs the fan's lifespan, and effectively reduces noise.
SILENT FAN PERFORMANCE WITH A ZERO SPEED MODE
A quieter, speedier fan features lower noise level output and improved airflow thanks to a higher RPM.
ADVANCED HEAT DISSIPATION
Purple anodic-coated heat sink with bevel cut lowers average temperatures, compared to traditional heat sinks. Bevel cuts bring out the heat source more effectively, and after concentrating the flow field, benefiting the heat dissipation.
CERTIFIED EFFICIENCY
An interleaved PFC decreases power loss and improves efficiency by inimizing current, reducing interference, and reducing output capacitor ripple current.
Durable Cable
FULLY MODULAR CABLING
A modular cable management design reduces clutter, increases airflow, and improves overall efficiency as well as thermal performance.
  • Model MPZ-D002-AFAP
  • Input Current 15-7A
  • Fan Size 135mm
  • Fan Bearing LDB
  • Fan Speed 2400±10% RPM
  • Hold Up Time ≥ 16ms
  • EPS 4+4 Pin Connectors 1
  • EPS 8 Pin Connector 1
  • SATA Connectors 16
  • PCI-e 6+2 Pin Connectors 5
  • 12V-2x6 Connectors 1
  • Series V Platinum Series
  • 80 Plus Efficiency Platinum
  • Category Above 750W
  • Watts 1300W
