V Platinum 1100 V2 image number 0
V Platinum 1100 V2 image number 1
V Platinum 1100 V2 image number 2
V Platinum 1100 V2 image number 3
V Platinum 1100 V2 image number 4
V Platinum 1100 V2 image number 5
V Platinum 1100 V2 image number 6
V Platinum 1100 V2 image number 7
V Platinum 1100 V2 image number 8
V Platinum 1100 V2 image number 9
V Platinum 1100 V2 image number 10
V Platinum 1100 V2 image number 11
V Platinum 1100 V2
V Platinum 1100 V2
V Platinum 1100 V2
V Platinum 1100 V2
V Platinum 1100 V2
V Platinum 1100 V2
V Platinum 1100 V2
V Platinum 1100 V2
V Platinum 1100 V2
V Platinum 1100 V2
V Platinum 1100 V2
V Platinum 1100 V2
QUIETLY SUPREME
V Platinum 1100 V2
Introducing the V Platinum V2, featuring an ultra-quiet Mobius fan, 80 Plus Platinum efficiency, and ATX 3.1 support with a durable 12V-2x6 cable.
Silent fan performance with a zero speed mode
Mobius fan enhances thermal performance and a longer lifespan.
An ultra-quiet Mobius fan featuring high-performance oil reflow, an innovative ring blade design, and accelerated pressure air vents provides improved noise levels and advanced thermal performance.
Advanced heat dissipation
Purple anodic-coated heat sink with bevel cut lowers average temperatures, compared to traditional heat sinks. Bevel cuts bring out the heat source more effectively, and after concentrating the flow field, benefiting the heat dissipation.
Mobius fan featuring a Ring Blade Design (RBD) for advanced heat dissipation
Certified Efficiency
An interleaved PFC decreases power loss and improves efficiency by minimizing current, reducing interference, and reducing output capacitor ripple current.
ATX 3.1 support & a durable 90° 12V-2x6 cable
Includes ATX 3.1 support and a 90° 12V-2x6 connector featuring more reliability, higher electrical durability, improved safety, and capable of bringing up to 600W to your GPU.
Fully modular cabling
A modular cable management design reduces clutter, increases airflow, and improves overall efficiency as well as thermal performance.
  • Model MPZ-B002-AFAP
  • Input Current 13-7A
  • Fan Size 135mm
  • Fan Bearing LDB
  • Fan Speed 2400±10% RPM
  • Hold Up Time ≥ 16ms
  • EPS 4+4 Pin Connectors 1
  • EPS 8 Pin Connector 1
  • SATA Connectors 16
  • PCI-e 6+2 Pin Connectors 5
  • 12V-2x6 Connectors 1
  • Series V Platinum Series
  • 80 Plus Efficiency Platinum
  • Category Above 750W
  • Watts 1100W
