Universal Vertical GPU Holder Kit ver.2 image number 0
Universal Vertical GPU Holder Kit ver.2 image number 1
Universal Vertical GPU Holder Kit ver.2 image number 2
Universal Vertical GPU Holder Kit ver.2 image number 3
Universal Vertical GPU Holder Kit ver.2 image number 4
Universal Vertical GPU Holder Kit ver.2 image number 5
MAKE OF IT WHAT YOU WILL
The Cooler Master Universal Graphics Card Holder Kit Version 2 comes redesigned for maximum compatibility and easy installation.
  • Warranty 1 year
  • Supported Graphics Cards Any length, up to 2.5 slots wide
  • Riser Cable Model Riser Cable PCie 3.0 Ver.2
  • Compatibility PCIe 3.0
  • Certifications EMI, IPC4101D/21
  • Electronic Component Materials PCBA, Copper Wire 28 AWG, Copper Wire 30 AWG
  • Insulation Materials PE
  • Other Materials ABS
  • Required PCI slots 7 PCI slots are required for mounting
  • Other Materials SPCC
  • Insulation Materials TPE
  • Color(s) Black
  • Other Materials SGCC Steel
  • Other Materials Nickel
  • Other Materials Gold
  • Legacy Accessories
  • Note This product is only compatible for devices that support the PCI-E 3.0 specification. If you use this product with a motherboard that supports PCI-E 4.0, please enter into BIOS option and select PCI-E 3.0 before installation.
  • Other Materials Brass
  • Note The Vertical GPU Holder Kit V2 can also accommodate 3-slots GPUs but allows installation of only 2 screws out of 3
  • Gross Weight 0.55kg
  • Net Weight 0.41kg
  • Dimensions (L x W x H) GFX Holder kit: 184 x 142 x 121mm / 7.25 x 5.59 x 4.77 inch (closed)
  • Dimensions (L x W x H) Riser cable: 165mm (6.49in)
  • UPC Code 884102075438
  • EAN Code 4719512103128
  • Model Number MCA-U000R-KFVK01
