Global Headquarters
Illuminating Perfection
Elevate your gaming setup with the Universal Vertical GPU Holder Kit ARGB and stand out among fellow gamers. Show off your components with pride and unlock the full potential of your gaming experience.
Ultra-flexible PCIe 4.0 riser cable enables high-speed data transmission with ease for tight cable routing.
Toollessly adjustable up to 65mm horizontally, as well as up to 30mm towards the side panel for easy installation.
Bring the best out of your components by showing off your GPU.
Designed for both ATX and mATX cases, this accessory is compatible with the latest GPUs available on the market.
