Universal Vertical GPU Holder Kit ARGB image number 0
Universal Vertical GPU Holder Kit ARGB image number 1
Illuminating Perfection
Elevate your gaming setup with the Universal Vertical GPU Holder Kit ARGB and stand out among fellow gamers. Show off your components with pride and unlock the full potential of your gaming experience.
Ultra-flexible PCIe 4.0 Riser Cable Included
Ultra-flexible PCIe 4.0 riser cable enables high-speed data transmission with ease for tight cable routing.
Tool-less, Instantly Adjustable Design
Toollessly adjustable up to 65mm horizontally, as well as up to 30mm towards the side panel for easy installation.
Effortlessly Showcase Your Graphics Card
Bring the best out of your components by showing off your GPU.
ATX & M-ATX
COMPATIBILITY
Designed for both ATX and mATX cases, this accessory is compatible with the latest GPUs available on the market.
  • Model Number MCA-U004R-AVGBST-00
  • Color(s) Black
  • Dimensions (L x W x H) GFX Holder Kit: 249 x 148.1 x 141.8mm (close size), GFX Holder Kit: 305 x 178.1 x 141.8mm (open size), Riser Cable: 165mm (6.19in)
  • Supported Chassis Type ATX, Micro ATX
  • Supported Graphics Cards Any length, up to 3 slots wide
  • Riser Cable Model Riser Cable PCIe 4.0 x16
  • Compatibility PCIe 4.0 and older
  • CE Certifications Number BKC24041591DC
  • Component Materials PCBA, Silver Plated Copper Wire 30 AWG
  • Insulation Materials PE, TPE
  • Other Materials ABS, PP, SGCC Steel, Nickel, Gold, Brass
  • Connectors PCIe x16 Male to PCIe x16 90° Female
  • Operating Temperature -20° to +100° Celsius
  • Required PCI slots Minimum 4 PCI slots required for mounting
  • Warranty 1 year
  • Series Others
