Thermal Pad Pro image number 0
Cooling Versatility Everywhere
Thermal Pad Pro
Cooler Master’s new Thermal Pad Pro is an innovative solution to device cooling for a vast range of your electronic devices and components.
THERMAL PAD PRO
COOLING VERSATILITY EVERYWHERE
THERMAL PAD PRO
Formulated with Nano Diamond Particles
Non-toxic and Non-corrosive
Double-sided Adhesive
Versatile and Easy Application.
Cooler Master's new Thermal Pad Pro is an innovative solution to device cooling for a vast range of your electronic devices and components.
FORMULATED WITH NANO DIAMOND PARTICLES
15.3w/mK thermal conductivity for rapid cooling, capable of drawing high levels of heat.
NON-TOXIC
AND NON-CORROSIVE
Safe and simple formula with electrically insulated and heat resistant properties to prevent hardening.
DOUBLE-SIDED ADHESIVE
Provides seamless and secure contact between surfaces.
VERSATILE AND EASY APPLICATION
Easily cut to the perfect size for your application. Choices of 1mm and 2mm thickness are available.
WIDE RANGE OF APPLICATION
Electronic devices, motherboards, components (CPU, GPU, USICS, Hard Drives, Disk Drives, IGBT module), laptops and various products requiring cooling.
  • Product Number TPY-NDPB-9010-R1, TPY-NDPB-9020-R1
  • Dimensions (L x W x H) 95 x 45 mm
  • Thermal Conductivity 15.3 (W/m.K)
  • Color Blue
  • Density 3.4 ± 0.2 g/cc
  • Hardness 30~55 Sc
  • Breakdown Voltage 6KV (1mm)
  • Working Temperature -40 ~ 200°C
  • Cooler Type Thermal Grease
