Tempered Glass Side Panel image number 0
Tempered Glass Side Panel for MasterCase5, 6, MC500, MC600, H500P and H500M
Overview
The tempered glass side panel bring a premium touch to your chassis and allow to highlight any system from water cooling advanced build up to the simpliest configuration.
The quality of the glass guarantee a long life durability and the bracket design hold the side panel to prevent any falls.
Compatible with:
• MasterCase 5 Series
• MasterCase 6 Series
• MC500 Series
• MC600 Series
• H500P & H500M
Overview
Overview
  • Units per package 1 piece per package
  • Model Number MCA-M500R-TGSP00-DBT (Dark Black Tinted)
  • Model Number MCA-M500R-TGSP00-LGT (Light Grey Tinted)
  • Color(s) Dark Black or Light Grey Tinted
  • Materials - Left Side Panel Tempered Glass, Steel, Plastic
  • Dimensions (L x W x H) 460 x 460 x 23 mm / 18.1 x 18.1 x 0.9 inch
  • Net Weight 2.2 Kg / 4.9 lb
  • Gross Weight 3.1 Kg / 6.8 lb
  • Warranty 1 year
  • Series Others
  • Legacy Accessories
  • Accessories Side Panels
