TD300 Mesh image number 0
TD300 Mesh image number 1
TD300 Mesh image number 2
TD300 Mesh image number 3
TD300 Mesh image number 4
TD300 Mesh image number 5
TD300 Mesh image number 6
TD300 Mesh image number 7
TD300 Mesh image number 8
TD300 Mesh image number 9
TD300 Mesh
TD300 Mesh
TD300 Mesh
TD300 Mesh
TD300 Mesh
TD300 Mesh
TD300 Mesh
TD300 Mesh
TD300 Mesh
TD300 Mesh
Postmodern Elegance
TD300 Mesh
Polygonal Mesh 3D Contour Front Panel
Removable Top Panel
Tempered Glass Side Panel
Dual CF120 ARGB Fans
ARGB/PWM Hub
Adaptable Drive Cage
Up to 280mm Radiator Support
Buy Now
  • Model Number TD300 Mesh: TD300-KGNN-S00, TD300 Mesh White: TD300-WGNN-S00
  • Exterior Color Black, White
  • Materials - Body Steel, Mesh, Plastic
  • Dimensions (L x W x H) 366.5 x 210 x 410mm (Body Size), 433 x 210 x 420.5mm (incl. Protrusions)
  • Volume 38.24L (incl. Protrusions)
  • Expansion Slots 4
  • 5.25" Drive Bays N/A
  • 2.5" Drive Bays 2
  • I/O Panel 1x 3.5mm Mic Jack
  • I/O Panel 1x ARGB Hub
  • Pre-installed Fans - Front 2x 120mm CF120 ARGB Fan
  • Pre-installed Fans - Bottom N/A
  • Fan Support - Front 3 x 120mm* / 2 x 140mm (*can only mount behind the front plate)
  • Fan Support - Rear 1x 120mm
  • Radiator Support - Front 120 / 140 / 240 / 280mm
  • Clearance - CPU Cooler 166mm
  • Clearance - PSU 325mm (w/o front radiator & drive cage), 140mm (drive cage in backmost position)
  • Clearance - GFX 344mm
  • Cable Routing - Behind Motherboard Tray 18-22mm
  • Size Mini Tower
  • Series MasterBox Series
