BUILD YOUR GAMING EXPERIENCE
Stryker SE
Stryker SE
MaterialsSteel
Radiator Support - Bottom120mm
Radiator Support - Rear120mm
Power Supply SupportBottom Mount
Dust FiltersTop
Cable Routing17.9mm
Pre-installed Fans - Rear1x 140mm, 1200RPM
Pre-installed Fans - Top1x 200mm
Fan Support - Bottom2x 120mm
LegacyCases
Dust FiltersFront
Radiator Support - Front360mm
Expansion Slots9+2
Radiator Support - Bottom140mm
Radiator Support - Rear140mm
MaterialsPlastic
3.5" Drive Bays2
I/O Panel2x USB 3.0
MaterialsTempered Glass
5.25" Drive Bays1
Color(s)White
Radiator Support - Bottom240mm
Dust FiltersBottom
Fan Support - Rear1x 120/140mm
Power Supply SupportATX
Drive Bays - 2.5" SSD4 + 1 (from X-Dock)
Motherboard SupportXL-ATX
Radiator Support - Front280mm
Radiator Support - Front240mm
Radiator Support - Top240mm
Dimensions (L x W x H)578.5 x 250 x 605.6mm
Pre-installed Fans - Front2x 120mm White LED Fan (1200RPM)
EAN Code4719512065402
UPC Code884102037924
Fan Support - Top2x 120/140mm
Motherboard SupportE-ATX
I/O Panel2x USB 2.0
Motherboard SupportATX
Radiator Support - Front140mm
Radiator Support - Top140mm
Fan Support - Top1x 200mm
Radiator Support - Top120mm
Radiator Support - Front120mm
Motherboard SupportMicro ATX
Motherboard SupportMini ITX
Fan Support - Front3x 120/140mm
Clearance - GFX322mm
Clearance - CPU Cooler186mm
I/O PanelAudio In & Out (Supports HD Audio)
I/O PanelFan Speed & LED on/off buttons
Model NumberSGC-5000W-KWN2
