Standard Fan 80mm
Standard Fan 80mm
Fan Rated Voltage12 VDC
Screws4 pcs
3 to 4 pin Adapter1 pcs
Fan Power Connector3-Pin
Fan Weight45g
LegacyCooling
Fan Life Expectancy35,000 Hours
Fan Dimensions (L x W x H)80 x 80 x 15 mm / 3.2 x 3.2 x 0.6 inch
Fan Bearing TypeSleeve Bearing
Fan Rated Current0.12A
Fan Power Consumption1.44W
Fan Noise Level20 dBA
Fan Air Pressure1.43 mmH2O
Fan Airflow24.2 CFM
Product NumberR4-SPS-20AK-GP
