Standard Fan 80 ST2 image number 0
Standard Fan 80 ST2 image number 1
Standard Fan 80 ST2
Standard Fan 80 ST2
Standard Fan 80 ST2
Standard Fan 80 ST2
  • Screws 4 pcs
  • 3 to 4 pin Adapter 1 pcs
  • Fan Power Connector 3-Pin
  • Legacy Cooling
  • Fan Weight 62g
  • Color Black
  • Fan Bearing Type LDB
  • Fan Air Pressure 2.34 mmH2O (Max)
  • Fan Rated Current 0.09A
  • Fan Dimensions (L x W x H) 80 x 80 x 25 mm / 3.1 x 3.1 x 1.0 inch
  • Fan Life Expectancy 50,000 Hours
  • Fan Rated Current 0.11A (Max)
  • Fan Power Consumption 1.2W
  • Fan Noise Level 21 dBA
  • Fan Airflow 28.89 CFM
  • Product Number R4-S8R-20AK-GP
