SK650 White Limited Edition Mechanical Keyboard image number 0
SK650 White Limited Edition Mechanical Keyboard image number 1
SK650 White Limited Edition Mechanical Keyboard image number 2
SK650 White Limited Edition Mechanical Keyboard image number 3
SK650 White Limited Edition Mechanical Keyboard image number 4
SK650 White Limited Edition Mechanical Keyboard image number 5
Strikingly Sleek
The SK650 White Limited Edition is a slim mechanical keyboard with all the signature Cooler Master features
  • Keyboard Type Mechanical
  • Product Keyboard
  • Material Aluminum
  • On-the-fly System Macro Record
  • Keyboard LED Color RGB
  • Keyboard Response Rate 1ms / 1000Hz
  • On-the-fly System Lighting Control
  • On-board Memory 512KB
  • Software Yes, Cooler Master Portal
  • Keyboard Connector Cable USB 2.0 Type A (Computer Side)
  • Keyboard Connector Cable USB Type-C (Keyboard Side)
  • Material Plastic
  • On-the-fly System Multimedia
  • Multimedia Keys Through Function Key (FN)
  • Color Silver
  • Color White
  • Cable USB Type-C Detachable & Braided
  • Cable Length 1.8m, Braided & Removable
  • Keyboard Switch Type Cherry MX RGB Low Profile Switch
  • Serie SK Series
  • Weight 629g / 1.387 lbs (without cable)
  • Dimensions (L x W x H) 430 x 125 x 25 mm
  • Product Number SK-650-SKLR1-**
