SK622 Space Gray White Hybrid Wireless Mechanical Gaming Keyboard image number 0
SK622 Space Gray White Hybrid Wireless Mechanical Gaming Keyboard image number 1
SK622 Space Gray White Hybrid Wireless Mechanical Gaming Keyboard image number 2
SK622 Space Gray White Hybrid Wireless Mechanical Gaming Keyboard image number 3
SK622 Space Gray White Hybrid Wireless Mechanical Gaming Keyboard image number 4
SK622 Space Gray White Hybrid Wireless Mechanical Gaming Keyboard image number 5
Modern Looks, Classic Touch
The SK622 hybrid wireless gaming keyboard takes a modern approach to the classic mechanical keyboard with low profile switches housed in a sleek...
  • Product Keyboard
  • Keyboard Material Plastic
  • Keyboard LED Color RGB
  • Wireless Connectivity Bluetooth 4.0
  • Keyboard Color Black
  • Disclaimer *To ensure optimal use of the product, please download the MasterPlus+ Software and update the latest firmware.
  • Keyboard Cable Length 1.8m, Braided & Removable
  • Keyboard MCU 32bit ARM Cortex M0
  • Keyboard On-board Memory 512 KB
  • Compatible OS Mac OS X 10.10+/iOS 5+/Android 3.2+/Windows 8 and above
  • Battery 4000mAh (2000mAh × 2)
  • Keyboard Connector Cable USB 2.0 Type A (Computer Side)
  • Keyboard Polling Rate 1000Hz (Wired Mode)
  • Keyboard Material Aluminum
  • Keyboard Connector Cable USB Type-C (Keyboard Side)
  • Keyboard Polling Rate 125Hz (Bluetooth Mode)
  • Keyboard Keycaps Ergonomic keycap
  • Software Support Cooler Master MasterPlus+
  • Multimedia Keys Through FN
  • On-the-fly System Yes
  • Keyboard Dimensions (L x W x H) Standard: 293 x 103 x 30.28 mm
  • Keyboard Dimensions (L x W x H) Feet Open: 293 x 103 x 43.03 mm
  • Keyboard Weight 446g / 0.983 lbs (without Cable)
  • Keyboard Switch Type TTC Low Profile Mechanical Switch (Red/Blue/Brown)
  • Product Number SK-622-GKTR1-**
  • Product Number SK-622-GKTM1-**
  • Product Number SK-622-GKTL1-**
