Silent Fan 120 SI1 image number 0
Silent Fan 120 SI1 image number 1
Silent Fan 120 SI1
Silent Fan 120 SI1
Silent Fan 120 SI1
Silent Fan 120 SI1
  • Screws 4 pcs
  • Fan Life Expectancy 30,000 Hours
  • 3 to 4 pin Adapter 1 pcs
  • Fan Speed 1200 RPM ± 10%
  • Cable Length 300mm
  • Fan Power Connector 3-Pin
  • Color Black
  • Cooler Type Case Fan
  • Fan Rated Current 0.07A
  • Fan Power Consumption 0.84W
  • Fan Bearing Type Sleeve Bearing
  • LED Lighting Non-LED
  • Fan Size 120
  • Fan Weight 120g
  • Series Standard
  • Fan Noise Level 19.8 dBA
  • Fan Air Pressure 1.83 mmH2O ± 10%
  • Fan Airflow 44.03 CFM ± 10%
  • Product Number R4-S2S-12AK-GP
  • CPU-Z - Cooler Master 32 & 64-bit versions Download
