Silencio S400 White Edition image number 0
Silencio S400 White Edition image number 1
Silencio S400 White Edition image number 2
Silencio S400 White Edition image number 3
Silencio S400 White Edition image number 4
Silencio S400 White Edition image number 5
Silencio S400 White Edition image number 6
Silencio S400 White Edition image number 7
Silencio S400 White Edition image number 8
Silence Has a Sequel
Silencio Design
Silencio Technology
Sound Dampening Material
Top & Front Ventilation
Reversible Steel Door
Silencio Design
Silencio Design
The Silencio’s minimalistic design cloaks its complexity. Design elements fine-tuned in form and function result in minimized noise and efficiently maintained system temperatures.
Silencio Technology
Silencio Technology
Behind the outer panels are pieces of meticulously placed sound dampening material. The development of the Silencio was driven by Sorama’s Cam64—this allowed for the entire sound spectrum to be visually analyzed by source, resonance pattern, and frequency.
With the identification of peaks within certain frequency ranges, fine-tuning the Silencio for the dispersion of resonance was made possible, reducing the prominence of noise generated by system components. Every detail in design optimized the Silencio for thermal efficiency and silence, from the type of material used to its placement.
Seamless Tempered Glass or Sound-dampened Steel
Available with seamless tempered glass or a sounddampened steel side panel, systems can be built for show or for stealth with the Silencio.
Top Panel Options
Reversible Steel Door & ODD Support
(re)movable Drive Cage
Motherboard Support
Motherboard Support
Mini-itx, Micro-atx
Cooling Support
Cooling Support
Top:
120 / 140mm x 1 Fans
120 / 140mm x 2* Fans
120 / 240mm* Radiator
*remove ODD cage
Front:
120 / 140mm x 2 Fans
120 / 140 / 240 / 280mm* Radiator
*may interfere with HDD mounted below ODD bracket
Rear:
120 x 1 Fan
120 x 1 Radiator
Storage Support
Storage Support
5.25inch ODD x 1
3.5inch HDD x 4
2.5inch SSD x 4
  • Model Number Steel: MCS-S400-WN5N-SJP, TG: MCS-S400-WG5N-SJP
  • Exterior Color Black
  • Materials - Body Steel, Plastic, Sound Absorbing Material
  • Materials - Left Side Panel Sound-Dampened Steel (MCS-S400-WN5N-SJP), Tempered Glass (MCS-S400-WG5N-SJP)
  • Dimensions (L x W x H) 418 x 210 x 408mm (incl. Protrusions), 403.5 x 210 x 400mm (excl. Protrusions)
  • Volume 33.9L (excl. Protrusions)
  • Expansion Slots 4
  • 5.25" Drive Bays 1
  • 3.5" Drive Bays 4
  • 2.5" Drive Bays 4
  • I/O Panel - USB Ports 1x USB 3.0, 1x USB 3.1 Type C
  • I/O Panel - SD Card Reader Supports SD & MMC Cards
  • Pre-installed Fans - Front 1x CF120 non-Led (White)
  • Pre-installed Fans - Rear 1x CF120 non-Led (White)
  • Fan Support - Top 1x 120mm, 1x 140mm / 2x 120mm, 2x 140mm (remove ODD cage)
  • Fan Support - Rear 1x 120mm
  • Radiator Support - Front 120 / 140 / 240 / 280mm (remove & reinstall ODD bracket to mount 280mm radiator, may interfere with HDD mounted below ODD bracket)
  • Radiator Support - Top 120mm, 240mm* (*240mm requires removal of ODD cage)
  • Clearance - CPU Cooler Steel: 167mm, TG: 166mm
  • Clearance - PSU 325mm (w/o front radiator & drive cage), 140mm (HDD cage in backmost position)
  • Clearance - GFX 319mm
  • Cable Routing 20mm
  • Size Mini Tower
  • Series Silencio Series
