Silencio FP 120 3PIN
Fan Rated Voltage12 VDC
Fan Power Connector3-Pin
LegacyCooling
Fan Power Consumption0.6W
Fan Rated Current0.05A
Fan Bearing TypeLoop Dynamic Bearing (LDB)
Fan Life Expectancy160,000 Hours
LEDNon-LED
Fan Safety Current0.5A
AccessoryMetal Screw x 4
Accessory3 to 4 pin Adapter x 1
AccessoryRubber Anti-vibration Screw x 4
Fan Noise Level11 dBA
Fan Weight158g / 0.35lb
Fan Speed1200 ± 200 RPM
Fan Airflow38 CFM ± 10%
Fan Air Pressure1.2 mmH2O ± 10%
Product NumberR4-SFNL-12FK-R1
