Silencio 450 image number 0
Silencio 450 image number 1
Silencio 450 image number 2
Silencio 450 image number 3
Silencio 450 image number 4
Silencio 450 image number 5
Silencio 450 image number 6
Silencio 450
Silencio 450
Silencio 450
Silencio 450
Silencio 450
Silencio 450
Silencio 450
Silencio 450
Silencio 450
  • Size Mid Tower
  • Legacy Cases
  • Series Silencio Series
  • I/O Panel 1x USB 2.0
  • Expansion Slots 7
  • Color(s) Midnight Black
  • Power Supply Support Standard ATX PS2 (optional)
  • Cooling System - Rear or 80/90mm fan x 1 (optional)
  • Materials Steel body
  • Maximum Compatibility - CPU Cooler Height 156.5mm / 6.16 inch
  • Maximum Compatibility - VGA Card Length 281mm / 11.1 inch (w/ HDD cage)
  • Cooling System - Rear 120mm x 1, 800 RPM silent fan pre-install
  • Materials Plastic bezel
  • 2.5" Drive Bays 1 (hidden)
  • 5.25" Drive Bays 3 (exposed)
  • I/O Panel 1x Mic
  • 3.5" Drive Bays 1 (exposed)
  • Weight 6.2 kg / 13.66 lbs
  • 3.5" Drive Bays 5 (hidden)
  • I/O Panel 1x SD card reader (Class 10)
  • Cooling System - Front 120mm x 1, 800rpm silent fan pre-install (converted to 120mm fan x 2 or 140mm fan x 1)
  • Maximum Compatibility - VGA Card Length 422mm / 16.6 inch (w/o HDD cage)
  • Dimensions (L x W x H) 194 x 451.45 x 494.75 mm / 7.63 x 17.77 x 19.47 inch
  • Model Number RC-450-KKN1
