Tempered Glass Side Panel for MasterBox 5 Series image number 0
Tempered Glass Side Panel for MasterBox 5 Series image number 1
Tempered Glass Side Panel for MasterBox 5 Series image number 2
Tempered Glass Side Panel for MasterBox 5 Series image number 3
Tempered Glass Side Panel for MasterBox 5 Series image number 4
Tempered Glass Side Panel for MasterBox 5 Series image number 5
Tempered Glass Side Panel for MasterBox 5 Series image number 6
Tempered Glass Side Panel for MasterBox 5 Series image number 7
Tempered Glass Side Panel for MasterBox 5, MasterBox Pro 5, MasteBox 5T
  • Materials Steel
  • Units per package 1 piece per package
  • Materials Tempered Glass
  • Gross Weight 2.47 Kg / 5.4 lb
  • Accessories Side Panels
  • Legacy Accessories
  • Net Weight 1.94 Kg / 4.3 lb
  • Color(s) Light Grey Tinted
  • Dimensions (L x W x H) 499 x 513 x 60 mm / 19.6 x 20.1 x 2.4 inch
  • UPC Code 884102041495
  • EAN Code 4719512068984
  • Model Number MCA-B501C-TGSP00-LGT
