SickleFlow X (Blue LED)
Fan Rated Voltage12 VDC
Fan Power Connector3-Pin
Adapter3 to 4 pin Adapter x 1
Fan Life Expectancy160,000 Hours
Cooler TypeCase Fan
LED LightingLED
Fan Size120
Fan Bearing TypePOM Bearing - Cooler Master 4th Gen. bearing (*POM: Polyoxymethelene)
NoteModel number and spec might be slightly different between regions
AccessoryMetal Screw x 4
Fan Weight109g
SeriesSickleFlow
Fan Noise Level19 dBA
Fan Speed2000 RPM ± 10%
Fan Rated Current0.35A
Fan Power Consumption4.2W
Fan Air Pressure2.94 mmH2O
Product NumberR4-SXDP-20FB-R1
