SickleFlow Edge 240 ARGB image number 0
SickleFlow Edge 240 ARGB image number 1
SickleFlow Edge 240 ARGB image number 2
SAME LEGEND, SHARPER EDGE
Multi-fan Configuration
Quick Connection
Easy Installation
Hollow Frame Structure
Loop Dynamic Bearing
Addressable RGB Lighting
MULTI-FAN CONFIGURATION
A single-frame unit enhances internal airflow, effectively expelling heat and significantly improving cooling efficiency.
QUICK CONNECTION
Uses one modular cable for lighting and power, simplifying management and improving aesthetics.
EASY INSTALLATION
Only 4 screws are needed for a hassle-free installation.
HOLLOW FRAME STRUCTURE
This lightweight yet durable fan module, featuring a hollow design with triangular vents ensures efficient airflow and long-lasting performance without adding bulk to your build.
LOOP DYNAMIC BEARING
Features our loop dynamic bearing, our in-house bearings, preventing dust and oil leakage and enhancing operational stability and lifespan.
ADDRESSABLE RGB LIGHTING
Experience vibrant and personalized lighting effects with addressable RGB, fully controllable through our in-house MasterCTRL software for seamless customization.
Discover MasterCTRL
  • Product Number MFX-B2DN-25DP2-R1
  • Exterior Color Black
  • Dimension (L x W x H) 241 x 122 x 26.5 mm / 9.5 x 4.8 x 1.02 inch
  • Fan Airflow 239.73 m³/h(141.1 CFM)​
  • Fan Noise Level 36 dBA (Max)
  • Bearing Loop Dynamic Bearing​
  • Fan Pressure 3.61 mmH₂O (Max)
  • Fan MTTF >160,000 Hours
  • Fan Rated Current 0.6A
  • Fan Safety Current 0.8 A
  • Fan Power Consumption 6 W
  • Warranty 5 years
  • LED Lighting ARGB
  • Fan Size 120
  • Cooler Type Case Fan
  • Series SickleFlow
