Global Headquarters
Same Legend, More Edge
Enhanced Fan Blade
Redesigned Fan Frame
Improved bearing system
A1 Mini LED Controller
The SickleFlow Edge 120 ARGB features an enhanced fan blade, a newly redesigned frame, a novel bearing system, and an ARGB gen 2 mini controller for maximal performance and triple the power.
An improved fan blade provides higher fan speed, air pressure, and airflow while sticking to the same low noise level the SickleFlow is known for.
The SickleFlow’s signature lines are now included in the frame design to provide a more cohesive product design.
An enhanced loop dynamic bearing system keeps things running silently smooth.
Control and customize your SickleFlow Edge 120 Fan Kit's lighting with a compact, easy-to-use mini controller.
