SickleFlow 120 ARGB White Edition 3 in 1 image number 0
SickleFlow 120 ARGB White Edition 3 in 1 image number 1
SickleFlow 120 ARGB White Edition 3 in 1 image number 2
SickleFlow 120 ARGB White Edition 3 in 1 image number 3
Choose The Most
Continuing the SickleFlow 120 series , Cooler Master introduces a few new models with brand new upgraded design features for enhanced performance.
SickleFlow 120 ARGB White Edition, a new series of the CoolerMaster Fan family, provides a specific air cooling solution ideal for CPU coolers and chassis in-take fans. Optimized blade design with updated curve that improves air flow and air pressure. Enhanced frame structure, reducing turbulent flow and noise and increasing overall work efficiency. Sealed and secured fan bearing, preventing dust and lubricating oil leakage while increasing the fan’s operation stability and life span.
Enhanced Fan Frame
Sealed Bearing Structure
  • Product Number MFX-B2DW-183PA-R1
  • Fan Speed 650-1800 RPM ± 10%
  • Fan Airflow 62 CFM ± 10%
  • Fan Air Pressure 2.5 mmH2O ± 10%
  • Fan Noise Level 8 - 27 dBA
  • Fan MTTF 160,000 Hours
  • RGB Connector 3-Pin ARGB
  • RGB Rated Voltage 5 VDC
  • RGB Rated Current 0.21A
  • Fan Rated Current 0.15A
  • Fan Safety Current 0.37A
  • Fan Power Consumption 1.8W
  • Fan Weight 156g / 0.34 lbs
  • Cooler Type Case Fan
  • Series SickleFlow
  • Fan Size 120
  • LED Lighting ARGB
  • Number of LEDs 6pcs x 3
