SickleFlow 120 ARGB 3 in 1 image number 0
SickleFlow 120 ARGB 3 in 1 image number 1
SickleFlow 120 ARGB 3 in 1 image number 2
SickleFlow 120 ARGB 3 in 1 image number 3
SickleFlow 120 ARGB 3 in 1 image number 4
Choose The Most
New Blade Design
Enhanced Fan Frame
Sealed Bearing Structure
Updated Lighting Design
Certified Compatible
UPDATED LIGHTING DESIGN
Featuring eclipse-mode lighting and enhanced lighting effects.
ENHANCED FAN FRAME
Enhanced frame structure, reducing turbulent flow and noise and increasing overall work efficiency.
NEW BEARING SEALANT
Improve dustproof properties as well as prevent sleeve lubricant from leaking.
NEW BLADE DESIGN
Optimized blade design with updated curve that improves air flow and air pressure.
SECURE CONNECTION
Includes Addressable RGB connector clips to ensure a secure connection
SICKLEFLOW 120  3 IN 1
SickleFlow 120 3in1, a new series of the CoolerMaster Fan family, provides a specific air cooling solution ideal for CPU coolers and chassis in-take fans. Optimized blade design with updated curve that improves air flow and air pressure. Enhanced frame structure, reducing turbulent flow and noise and increasing overall work efficiency. Sealed and secured fan bearing, preventing dust and lubricating oil leakage while increasing the fan’s operation stability and life span.
ADDRESSABLE RGB CONTROLLER
With Included Addressable RGB Controller, You can choose your favorite color easily. It also support lighting RESET button of Case.
  • Product Number MFX-B2DN-183PA-R1
  • Fan Speed 650-1800 RPM ± 10%
  • Fan Airflow 62 CFM ± 10%
  • Fan Air Pressure 2.5 mmH2O ± 10%
  • Fan Noise Level 8 - 27 dBA
  • Fan MTTF 160,000 Hours
  • RGB Connector 3-Pin ARGB
  • RGB Rated Voltage 5 VDC
  • RGB Rated Current 0.21A
  • Fan Rated Current 0.15A
  • Fan Safety Current 0.37A
  • Fan Power Consumption 1.8W
  • Fan Weight 156g / 0.34 lbs
  • Cooler Type Case Fan
  • Series SickleFlow
  • LED Lighting ARGB
  • Fan Size 120
  • Number of LEDs 6pcs x 3
