Scout 2 Advanced Gunmetal Gray image number 0
Scout 2 Advanced Gunmetal Gray image number 1
Scout 2 Advanced Gunmetal Gray image number 2
BUILT FOR INVINCIBLE GAMERS
  • Color(s) Gun Metal Grey
  • Cooling System - HDD cage 120mm fan x 1 (optional)
  • Cooling System - Bottom 1x 120mm Fan (Optional)
  • Size Mid Tower
  • I/O Panel 2x USB 3.0
  • Cooling System - Side 120mm fan x 2 (optional)
  • Legacy Cases
  • Cooling System - Top 120mm fan x 2 (optional)
  • Cooling System - Rear 120mm black fan x 1 (pre-installed)
  • I/O Panel 2x USB 2.0
  • Expansion Slots 7
  • Motherboard Support ATX
  • Power Supply Support Standard ATX PS2 (optional)
  • Materials Polymer
  • Maximum Compatibility - CPU Cooler Height 162mm / 6.4 inch
  • Maximum Compatibility - VGA Card Length 287mm / 11.3 inch (with HDD cage)
  • Materials Coated Steel Mesh and Body
  • 5.25" Drive Bays 3 (exposed)
  • 3.5" Drive Bays 7 (hidden)
  • Cooling System - Front 120mm red LED fan x 1
  • I/O Panel 1x Mic
  • Maximum Compatibility - VGA Card Length 399mm / 15.7 inch (w/o HDD cage)
  • Net Weight 8.45 kg / 18.6 lbs
  • 2.5" Drive Bays 4 (converted from 3.5" drive bays)
  • Dimensions (L x W x H) 513 x 230 x 517 mm / 20.2 x 9.1 x 20.5 in
  • Model Number SGC-2100-GWN3
