Scout 2 image number 0
Scout 2 image number 1
Scout 2 image number 2
Scout 2 image number 3
Scout 2 image number 4
Scout 2 image number 5
Scout 2
Scout 2
Scout 2
Scout 2
Scout 2
Scout 2
BUILT FOR INVINCIBLE GAMERS
Scout 2
Scout 2
  • Materials Steel
  • Fan Cooling Mounts - Front 2x 120mm
  • Special Features Carrying Handle
  • Fan Cooling Mounts - Side 2x 120mm
  • Fan Cooling Mounts - Bottom 1x 120mm
  • Fan Cooling Mounts - HDD Cage 1x 120mm
  • Included Cooling Devices - Rear 1x 120mm Black Fan, 1200 RPM, 17 dBA
  • Max GPU/PCI Card Length 287mm / 11.3" (w/ HDD cage)
  • Fan Cooling Mounts - Front or 1x 140mm
  • Fan Cooling Mounts - Top 2x 120mm
  • I/O Panel 2x USB 3.0
  • Size Mid Tower
  • Included Cooling Devices - Rear 1x 120mm Red LED Fan, 1200 RPM, 17 dBA
  • Legacy Cases
  • Fan Cooling Mounts - Rear 1x 120mm
  • Max GPU/PCI Card Length 399mm / 15.7" (w/o HDD cage)
  • 2.5" Drive Bays 2 (converted from one 3.5" drive bay)
  • I/O Panel 2x USB 2.0
  • Motherboard Support ATX
  • Expansion Slots 7
  • Power Supply Support Standard ATX PS2 (optional)
  • Materials Polymer
  • Materials Mesh
  • 5.25" Drive Bays 3 (exposed)
  • 3.5" Drive Bays 7 internal
  • Net Weight 8.3 kg / 18.3 lbs
  • Dimensions (L x W x H) 517.5 x 230 x 513mm, 20.5 x 9.1 x 20.2 inch
  • Color(s) KWN1 - Black external
  • Color(s) GWN1 - Gunmetal Grey external
  • Weight 10.49 kg / 23.1 lbs
  • Dimensions (L x W x H) 575 x 280 x 565mm / 22.6 x 11.0 x 22.2 inch
  • Model Number SGC-2100-KWN1
  • Model Number SGC-2100-GWN1
