Scout 2 (SGC-2100-KWN1-V2) image number 0
Scout 2 (SGC-2100-KWN1-V2) image number 1
Built for Invincible Gamers
  • Size Mid Tower
  • I/O Panel 2x USB 3.0
  • Cooling System - Front 120 mm LED fan x2 (1200 RPM, 17dBA)
  • Cooling System - Bottom 1x 120mm Fan (Optional)
  • Legacy Cases
  • Cooling System - Rear 120mm red LED fan x 1, 1200RPM, 17dBA
  • Cooling System - Top 120mm fan x 2 (optional)
  • 2.5" Drive Bays 2 (converted from one 3.5" drive bay)
  • I/O Panel 2x USB 2.0
  • Expansion Slots 7
  • Color(s) Midnight Black
  • Motherboard Support ATX
  • Power Supply Support Standard ATX PS2 (optional)
  • Materials Polymer
  • 3.5" Drive Bays 3 (hidden)
  • Materials Coated Steel Mesh and Body
  • 5.25" Drive Bays 3 (exposed)
  • I/O Panel 1x Mic
  • Net Weight 8 kg / 17.64 lbs
  • Maximum Compatibility - VGA Card Length 399mm / 15.7 inch (w/o HDD cage)
  • Dimensions (L x W x H) 517.5 x 230 x 513mm, 20.5 x 9.1 x 20.2 inch
  • UPC Code 884102027635
  • EAN Code 4719512050194
  • Model Number SGC-2100-KWN1-V2
