Scout 2 Ghost White image number 0
Scout 2 Ghost White image number 1
Scout 2 Ghost White image number 2
Scout 2 Ghost White image number 3
Scout 2 Ghost White image number 4
Scout 2 Ghost White image number 5
Scout 2 Ghost White image number 6
Scout 2 Ghost White image number 7
Scout 2 Ghost White image number 8
Scout 2 Ghost White image number 9
Scout 2 Ghost White image number 10
Scout 2 Ghost White image number 11
Scout 2 Ghost White
Scout 2 Ghost White
Scout 2 Ghost White
Scout 2 Ghost White
Scout 2 Ghost White
Scout 2 Ghost White
Scout 2 Ghost White
Scout 2 Ghost White
Scout 2 Ghost White
Scout 2 Ghost White
Scout 2 Ghost White
Scout 2 Ghost White
BUILT FOR INVINCIBLE GAMERS
Scout 2 Ghost White
Scout 2 Ghost White
  • Fan Cooling Mounts - HDD Cage 1x 120mm
  • Legacy Cases
  • I/O Panel 2x USB 3.0
  • Size Mid Tower
  • Cooling System - Bottom 1x 120mm Fan (Optional)
  • Cooling System - Side 120mm fan x 2 (optional)
  • Cooling System - Top 120mm fan x 2 (optional)
  • Cooling System - Rear 120mm black fan x 1 (pre-installed)
  • I/O Panel 2x USB 2.0
  • Expansion Slots 7
  • Color(s) Midnight Black
  • Power Supply Support Standard ATX PS2 (optional)
  • Maximum Compatibility - CPU Cooler Height 162mm / 6.4 inch
  • Maximum Compatibility - VGA Card Length 287mm / 11.3 inch (with HDD cage)
  • 5.25" Drive Bays 3 (exposed)
  • I/O Panel 1x Mic
  • Maximum Compatibility - VGA Card Length 399mm / 15.7 inch (w/o HDD cage)
  • Color(s) Gunmetal Grey
  • Cooling System - Front 120mm white LED fan x 2 (with LED on/off function)
  • Net Weight 8.56 kg / 18.87 lbs
  • 2.5" Drive Bays 4 (converted from 3.5" drive bays)
  • Color(s) Ghost White
  • Dimensions (L x W x H) 230 x 513 x 517.5 mm / 9.1 x 20.2 x 20.5 inch
  • Model Number SGC-2100-WWN1
