RISER CABLE PCIE 5.0 X16 200MM image number 0
RISER CABLE PCIE 5.0 X16 200MM image number 1
RISER CABLE PCIE 5.0 X16 200MM image number 2
RISER CABLE PCIE 5.0 X16 200MM image number 3
Flex Your Graphics Muscle
• PCIe 5.0 Compatible
• Ultra Durable PCB
• Heavy Duty Shielding
• Gold-plated Pin Connections
• Protective ABS Casing
• Ultra-flexible Cable Sleeves
The Cooler Master Riser Cable PCIe 5.0 x16 – 200mm is engineered for superior data transmission, maximum flexibility, and long-lasting durability. High-quality plastic materials enhance cable strength and flexibility, ensuring easy installation even in the tightest PCIe slots. ​
Heavy-duty shielding protects against electromagnetic interference, preserving signal integrity and stability. Meanwhile, the multi-layer coated PCB delivers industry-leading cable flex, moisture resistance, and reliable performance under high thermal loads.​
PCIe 5.0 Compatible
Providing twice the bandwidth of PCIe 4.0, the Gen 5.0 riser cable delivers a maximum transfer rate of over 128Gb/s (bi-directional). It remains fully backwards compatible and supports the 32GT/s bit rate of PCIe 5.0 devices.
Ultra Durable PCB
The multi-layer coated PCB offers best-in-class cable flex, moisture resistance, and reliable performance under high thermal loads.
EMI-shielded 30 AWG copper wires ensure minimal signal delay and stable, interference-free operation.
Gold-plated PCI pins are rated for 400g of retention force per contact pair, ensuring maximum lifespan and durability.
UV-resistant ABS casing protects cable connection points from rough handling.
TPE cable sleeves provide maximum flexibility and durability, ideal for the tightest cable routing jobs.​
  • Product Name RISER CABLE PCIE 5.0 X16 -200MM
  • Color(s) Black / White
  • Model Number Black: MCA-U000C-KPCI50-200
  • Model Number White: MCA-U000C-WPCI50-200
  • Component Materials Black: PCBA, tinned copper wire 30 AWG
  • Component Materials White: PCBA, silver plated copper wire 30 AWG
  • Insulation Materials FEP (Cable), PA10T + 35%GF (Connector)
  • Other Materials ABS, Nickel, Gold, PP, Brass
  • Compatibility PCIe 5.0 and older
  • CE Certifications Number BKC25093934JC
  • Connectors PCIe x16 Male to PCIe x16 90° Female
  • Cable Length 200mm (7.9in)
  • Working Voltage / Current DC 12V / 3.3V/3.3Vaux A,75W(Max)
  • PCB / Wire UL Numbers E467745 / E527405
  • Operating Temperature -20° to +80° Celsius
  • Net Weight 112 g
  • Gross Weight 163 g
  • Warranty 1 year
