Riser Cable PCIe 3.0 x16 VER. 2 - 200mm image number 0
Riser Cable PCIe 3.0 x16 VER. 2 - 200mm image number 1
Riser Cable PCIe 3.0 x16 VER. 2 - 200mm image number 2
Riser Cable PCIe 3.0 x16 VER. 2 - 200mm image number 3
Flex your Graphics Muscle
The Cooler Master Riser Cable PCIe 3.0 x16 Ver. 2 -200mm comes revised for maximum flexibility and durability.
  • Warranty 1 year
  • Units per package 1 piece per package
  • Compatibility PCIe 3.0
  • Certifications EMI, IPC4101D/21
  • Insulation Materials PE
  • Other Materials ABS
  • Connectors PCI-E x16 Male to PCI x16 90° Female
  • Contact Current Rating 1.1A per contact pin
  • Operating Temperature -20° to +100° Celsius
  • Color(s) Black
  • Insulation Materials TPE
  • Cable Length 200mm
  • Weight 90g
  • Other Materials Nickel
  • Other Materials Gold
  • Legacy Accessories
  • Note This product is only compatible for devices that support the PCI-E 3.0 specification. If you use this product with a motherboard that supports PCI-E 4.0, please enter into BIOS option and select PCI-E 3.0 before installation.
  • Other Materials Brass
  • Other Materials Stainless Steel
  • Materials PCBA
  • Materials Copper Wire
  • UPC Code 884102073823
  • EAN Code 4719512101520
  • Model Number MCA-U000C-KPCI30-200
