New
Compact Case, Unlimited Creativity
QUBE 540
Designed for creators, gamers, and DIY builders.
Perfect for small apartments, dorm rooms, and creators on the move, the QUBE 540 fits your life as well as your PC.
Compact Yet Capable
Small size, big performance. The QUBE 540 supports GPUs up to 415 mm, 360 mm liquid coolers, and high-end components.
Flexible Orientation Design
Vertical or horizontal, the QUBE 540 adapts to your space and style. It fits cleanly wherever you place it.
Create Your Own Layout
A modular interior designed for endless creativity, for liquid-cooling setups to compact workstations. Customize it your way.
Repositionable I/O Panel and Movable Handles
Mount the I/O panel and handles on the top, bottom, left, or right to keep ports and grips where you need them.
Versatile Modular Layout
Oce case, countless possibilities. Redefine your build anytime with swappable components and flexible layouts.
Vertical GPU Ready
Supports vertical GPU installation to highlight premium graphics and aesthetics.
ACCESSORY ECOSYSTEM
The Qube 540 comes with a living accessory ecosystem as we have prepared 3D-printable files for you to create your own accessories.
Cooler Master: FreeForm Playground
We’re teaming up with Printables to challenge makers worldwide. Take our modular hardware and make your own Qube 540!
