QUBE 340/ Q300L V3 image number 0
QUBE 340/ Q300L V3 image number 1
QUBE 340/ Q300L V3 image number 2
QUBE 340/ Q300L V3 image number 3
QUBE 340/ Q300L V3 image number 4
QUBE 340/ Q300L V3 image number 5
QUBE 340/ Q300L V3 image number 6
QUBE 340/ Q300L V3 image number 7
QUBE 340/ Q300L V3 image number 8
QUBE 340/ Q300L V3 image number 9
QUBE 340/ Q300L V3
QUBE 340/ Q300L V3
QUBE 340/ Q300L V3
QUBE 340/ Q300L V3
QUBE 340/ Q300L V3
QUBE 340/ Q300L V3
QUBE 340/ Q300L V3
QUBE 340/ Q300L V3
QUBE 340/ Q300L V3
QUBE 340/ Q300L V3
Powerfully Compact and Cool
QUBE 340/ Q300L V3
  • Mini-ITX / Micro-ATX Support
  • High Airflow Cooling Design
  • Optimum Clearance Design
  • Adjustable I/O Panel
  • Vertical & Horizontal Orientation
  • QUBE Accessory Ecosystem Support
POWERFUL COOLING CAPABILITY
High-airflow front panel and support for multiple fan and radiator keeps systems running cool and smooth.
PERFORMANCE IN PERFECT FIT
Provides generous components clearance to enable high-performance, compact builds.
ACCESS MADE EASY
Position the I/O panel on the top or bottom to keep connections within easy reach.
FLEXIBLE ORIENTATIONS
Whether vertical or horizontal, tailor builds to fit any space, setup, and workflow.
SPECIFICATIONS - QUBE 340(Default Version)
  • Product Name QUBE 340
  • Version Default Version
  • Product Series QUBE Series
  • Color - Black Q340-KGNN-S00
  • Color - White Q340-WGNN-S00
  • Materials SGCC + TG / Mesh
  • Dimension (L x W x H) - Incl. Protrusions 386.1 x 230 x 429.4 mm
  • Dimension (L x W x H) - Excl. Protrusions 374 x 230 x 374 mm
  • Dimension (L x W x H) - Volume (Incl. Protrusions) 38.13 L
  • Dimension (L x W x H) - Volume (Excl. Protrusions) 32.17 L
  • Clearances - CPU Cooler 178 mm
  • Clearances - Power Supply 200 mm (without bottom fan installed); 140 mm (with bottom fan installed)
  • Clearances - Graphics Card 366 mm (without front fan installed)
  • Expansion Slots 4
  • Drive Bays - 5.25" NA
  • Drive Bays - 3.5" 1
  • Drive Bays - 3.5" / 2.5" Combo 1
  • Drive Bays - 2.5" Drive Bay 2 (max 4)
  • Fans Support - Top 2 x 120 mm / 2 x 140 mm
  • Fans Support - Front 2 x 120 mm / 2 x 140 mm
  • Fans Support - Rear 1 x 120 mm / 1 x 140 mm
  • Fans Support - Bottom 1 x 120 mm / 1 x 140 mm
  • Fans Support - Side (Left/Right) NA
  • Pre-installed Fans - Rear 1 x 140 mm non-ARGB Black
  • Radiator Support - Top 240 / 120 mm
  • Radiator Support - Front 240 / 120 mm
  • Radiator Support - Bottom N/A
  • Radiator Support - Side (Left/Right) N/A
  • I/O Panel - USB Ports 2 x USB 3.2 Gen1 Type-A; 1 x USB 3.2 Gen 2x2 Type-C
  • I/O Panel - Audio In / Out 1 x 3.5 mm Mic / Audio Combo Jack
  • Cable Routing (Behind MB Tray) 30mm
  • Power Supply Support ATX
  • Dust Filters Top / Front / Bottom
  • Included Accessories 1 x Filter / 1 x Holder
  • Warranty 2 Years
PRODUCT SPECIFICATIONS - Q300L V3(Lite Version)
  • Product Name Q300L V3
  • Version Lite Version
  • Color - Black Q300LV3-KGNN-S00
  • Color - White Q300LV3-WGNN-S00
  • Dimension (L x W x H) - Incl. Protrusions 386.1 x 230 x 388.5 mm
  • Dimension (L x W x H) - Volume (Incl. Protrusions) 34.5 L
  • Expansion Slots 4
  • Radiator Support - Rear 120 mm
  • Cable Routing (Behind MB Tray) 30 mm
  • Included Accessories N/A
  • Warranty 2 Years
