Q300L V2 image number 0
Q300L V2 image number 1
Q300L V2 image number 2
Q300L V2 image number 3
Q300L V2 image number 4
Q300L V2 image number 5
Q300L V2 image number 6
Q300L V2 image number 7
Q300L V2 image number 8
Q300L V2 image number 9
Q300L V2 image number 10
Q300L V2 image number 11
Q300L V2 image number 12
Q300L V2 image number 13
Q300L V2 image number 14
Q300L V2
Q300L V2
Q300L V2
Q300L V2
Q300L V2
Q300L V2
Q300L V2
Q300L V2
Q300L V2
Q300L V2
Q300L V2
Q300L V2
Q300L V2
Q300L V2
Q300L V2
Refresh Your Style
Q300L V2
High Flexibility for System Building
Minimized Dimension with ATX PSU Support
Redesigned Patterned Dust Filter
Clean Routing Space
Excellent Thermal Performance
Edge-to-Edge Temper-Glass Side Panel
New Design
Magnetic Dust Filter
The redesigned dust filter keeps your PC breathing easy
with a refreshed patterned design.
Ports & Slots
USB 3.2 GEN2 2x2 Supported
USB 3.2 Gen 2x2 Type C port built into the I/O panel with data transfer speeds up to 20Gbps.
Design
Clean Routing Space
Air Flow
Edge To Edge Tempered Glass Side Panel
Design
Show off your build through the 4mm-thick tempered glass side panel, easily installed with thumbscrews.
  • Model Number Black: Q300LV2-KGNN-S00, White: Q300LV2-WGNN-S00
  • Exterior Color Black, White
  • Materials - Exterior Steel, Plastic
  • Dimensions (L x W x H) 387 x 230 x 383mm (incl. Protrusions), 370 x 210 x 370mm (excl. Protrusions)
  • Volume 29L (excl. Protrusions)
  • Expansion Slots 4
  • 5.25" Drive Bays 0
  • 3.5" Drive Bays 1
  • 2.5" Drive Bays 2
  • I/O Panel - Audio In / Out 1x Audio Jack
  • Pre-installed Fans - Rear Black: 1x 120mm, White: 1x 120mm (none LED, white)
  • Fan Support - Top 2x 120mm
  • Fan Support - Rear 1x 120mm
  • Fan Support - Bottom 1x 120mm
  • Clearance - CPU Cooler 159mm
  • Clearance - PSU 160mm
  • Clearance - GFX 360mm
  • Cable Routing - Behind Motherboard Tray 28mm
  • Size Mini Tower
  • Series QUBE Series
