Promo
Pocket Your Passion
Oracle Air
Oracle Air features a unique dual-layer design that allows for advanced heat dissipation that still keeps the device cool to the touch.
Full tool-less installation allows for easy upgrades and quick access between multiple SSDs, so users can work and play on the go.
Blistering Speed, On-the-Go
Whether you’re gaming, editing, or creating on the fly, the Oracle Air easily transfers data at speeds up to 1000MBps.
Dual Layer Cooling
A unique dual layer design allows for highly effective heat distribution and rapid cooling while remaining cool to the touch.
Install in Seconds
Oracle Air keeps things simple and intuitive by completely omitting the need for screws or tools during installation.
Plug and Play, MOLLE Compatible
Easily attach Oracle Air onto backpacks and more, facilitating instant access to countless games and files.
Support
Multi Platform
Enjoy native support for all major platforms including
PlayStation, Windows, Mac OS, Linux, Android, and iOS.
Our Achievements
3 Awards
