Global Headquarters
Compact Power, Refined Design
The NR200P V3 is crafted for creators, gamers, and PC DIY enthusiasts who demand both performance and style. Optimized for the latest NVIDIA 50-series GPUs, it features enhanced airflow, PCIe Gen5 support, and premium materials in a sleek ITX form factor.
Whether you're chasing high frame rates or a clean aesthetic, the NR200P V3 delivers powerful cooling and endless customization options—ready for your next-gen build.
Support for 240mm and 280mm AIO liquid coolers enables powerful thermal performance to handle high-end components with ease.
With optimized airflow design, your system stays cool and stable—even under heavy loads.
Includes a PCIe 5.0 riser cable and supports vertical GPU installation up to 361.5mm in length and 160mm in height.
A built-in support bracket ensures rock-solid stability—even for today’s largest graphics cards.
Large mesh side panels boost airflow and help reduce dust.
Easily switch between maximum cooling or a sleek closed look—your build, your style.
CNC-machined aluminum side panels with magnetic latching offer seamless tool-free access.
Enjoy effortless upgrades and maintenance—while preserving a clean, minimalist aesthetic.
Includes a PCIe 5.0 riser cable to ensure high-speed, stable GPU connectivity. Ready for the bandwidth demands of next-generation graphics cards, while enabling a clean vertical GPU installation.
Equipped with the latest USB 3.2 Gen 2x2 Type-C for blazing 20Gbps speeds.
Perfect for creators, gamers, and anyone who demands high-speed performance.
